Playback bar stuck as aligned for Hog4Wing
Playback bars can be moved around & resized at will, but once a playback bar has been set to 'Align4Wing' it doesn't seem possible to undo this and you're stuck with it for as long as you're running the same show.
Is there a way to reset to default, or toggle the 'Align4Wing' to off?
