Master control of programmers in network
If this is already available, please do let me know...it's not something I have ever found out how to achieve.
Can it be made possible that you can clear out a programmer on a different console on the network?
Using OSC control recently, I had a few occasions where my production electrician has forgotten to clear the programmer of the Net 2 console, to which his remote was connected. I was programming on the Net 1 console and occasionally needed to clear what he had accidentally left up, which was affecting the look onstage. It would be nice to be able to open the programmer of the net 2 console on the net 1 console and have the ability to view it and also clear it out.
Obviously having separate programmers across the network is a hugely powerful feature but being able to take control of other programmers on the network would take it to the next level.
Parents
  • I was trying this scenario with 2 different computers both running hog4pc set as desk number 1 and 2 respectively.
    I've found other oddities as well. I.E. if you play the dummy cuelist to trigger the macro directly from the cuelist window playback bar it works always despite having the cuelist with 1 or 2 cues and despite the fact the list is set as wrap at the beginning of the cue list, release at end and so forth......
Reply
Children
No Data
