Live Blind Mode
I do quite a lot of programming lights on the fly for festivals, concerts, dances, and the like. HOG is already laid out quite well for this sort of thing, but there is a feature that I thought up one night that would add an even greater level of flexibility for situations where one has very little (if any) lead time to program cues.
Imagine a mode that, if enabled, allows you to make changes in the programmer and effects engine without affecting the current output, until you trigger the changes you have made to go.
Obviously, you can achieve this currently by recording what you have running as a cue, opening the cue and changing parameters there with the current blind system. But if you were able to cut out the cue system entirely, this in combination with the existing palate system and effects engine would make an extremely powerful tool for those of us who make the majority of our living busking!
Also, a locking clear key to prevent the show from stopping accidentally!! :p
Parents
  • [QUOTE=Wolfblade;66333]I'd like a way to make changes to what is in the programmer without any change to the output, and then be able to trigger all these changes at once - without a blackout or having to mess around with recording cues. Thanks!
    Sounds like you need to look at using multiple editors.
    Record some blank/empty Scenes. You can then Open one of these to have another editor in addition to the Programmer....keep it Blind, then when you want it to go live un-Blind.
    If you get confused as to which Editor is currently "active" look to the right side of the command line.
    Hope this helps. :)
Reply
    Hope this helps. :)
Children
No Data
