It would be nice to have a feature where you can change the name of a list either while in the cuelist is open or while you are in the list's Playback Options window where you can set all of the other parameters about a list.
On the cuelist's open window it could simply be another button, along with Options and Play Controls, that opens a new dialog box to allow the name to be changed or if on the Playback Options window it could be added as another field on that window's Cuelist tab.
I find myself recording lots of cuelists and I know you can change the name of the cue by hitting Set right after record. I either have to go open the Lists window and change the name there or keep track of what List 1-N is so I can later give it a proper name. Lots of time I will open the cuelist to remind myself what it is for only to have to go back to the Lists window to change the name.
Let me know if I am missing some other feature that makes this process easier.
Kevin Montagne
