Rem Dim is the Devil
There is the Knockout button which knocks out the light in the programmer.
Next to it is the "You're Out" button, [Rem Dim] which gets you fired!:aargh4:
I'd like to request an option from the preferences to disable the Rem Dim button. I understand it has a great function for focusing lights on stage, but to me it is a liability next to a frequently used Knockout.
Parents
  • [QUOTE=Playdoe9;67779]I understand it has a great function for focusing lights on stage, but to me it is a liability next to a frequently used Knockout.
    If you are worried about "fat-fingering" the Rem Dim button try using the Backspace key to Knockout instead. Backspace+Fixture will Knockout every parameter for selected fixtures in the Programmer/Active Editor for example. Also works with IPCB +Kinds for selective Knockouts.
    Hope this helps. :)
Reply
    Hope this helps. :)
Children
No Data
