Global Desk "Beat Tap Rate"
The current Beat Tap functionality on the H4 is a great feature, but how about taking it a few steps further? Currently we can only use Beat Tap on a chase and unfortunately, cannot apply that defined rate to the FX engine or Cue FX rate..
I was thinking of how useful a "Global Beat Tap" rate would be... Lemme explain my complete idea.
Somewhere on the desk give the user the ability to tap out a beat. This rate is then stored in the console as a "Global Beat Tap Rate" that can be linearly adjusted via an encoder, master rate wheel or re tapping out another rate. Then in each of the options settings in the Masters, Cues Or Scenes, give us a drop down to be able to select either, "Local Rate" (The rate defined only within that cue, master, or scene) or "Global Rate" (The global rate defined by the global beat tap or encoder wheels). Then also give us the ability after defining a rate source, to define a multiple of that rate, (like, 1x, 2x, 3x, 4x or even 0.5x, 0.25x etc) and also give us the option to offset that rate to apply it to a downbeat or upbeat. In addition and probably the most important feature of this request, is the ability to take the "Global Rate" and apply it to the FX within a cue, master or scene, not just a chase.
This feature set will give the programmer the ability to very quickly sync up a tempo and then quickly apply it anywhere in the desk at any multiple and any offset.
Please consider as this would be an amazing feature...
JB
Parents
  • So update V2.2.0 has some added functionality regarding the FX tempo issues.
    The global tap or even the possibility to set your own tap tempo key for a master isn't possible yet.
    What about setting the bpm of an effect on a playback via OSC?
    I could easily hack something together with an arduino to make my own tap tempo box using OSC to send the BPM (even using a foot switch if I want)
    All it would need is the desk to tell me via OSC what playback is selected and the possibility to send effect BPM and playback rate to a playback.
    EDIT:
    I could know what playback is selected already via the led status which is already on OSC
Reply
    EDIT:
Children
No Data
