Hi there,
I haven't been able to do the following while using the console myself so if this is already possible then please help otherwise it would be really useful if it was possible to use the 'Full' button when inputting data into the programmer fields.
For example if I highlight some moving lights intensity fields in the programmer on the touchscreen i would like to hit
'SET' then 'FULL' 'ENTER'
for the values to hit there max value (for Intensity 100%).
Additionally if I highlight Pan it would be good to use
or
'SET' then 'MINUS' 'FULL' 'ENTER'
to enter the maximum Positive or Maximum Negative value respectively.
What are your thoughts?
Colin
