I have not been able to find a workable solution for this but I would like the ability to either disable or re-task the GM to reduce a common user error that my volunteers tend to run into often. It would be helpful if I could do that, in particular with a playback wing. I have a FB4 with a PB wing 4. Another option if possible maybe to re-task the GM as a House light fader and maybe even use on screen keys to change between different setup of those houselights (like when the room is not full and I need to dim the outside or FOH houselights. Just my 2 cents. I realize that could give me 2 house light faders but at least they are synched together with the motorized faders.
I'm sorry but we only allow you to resign the GM's Flash button not the fader. And we only allow it the following options: NO ACTION, FULL, ZERO or OPPOSITE
