Not sure if this has already been asked for (I think I might have asked myself but can't find it!!)
I have just finished patching a show where they had 4 different fixtures that needed to be patched as multi part and they had about 40 Atomics that originally had scrollers and so therefore a 1 DMX offset!
It would be nice if you could patch multiple fixtures with an off-set.
As in fixtures 1 thru 30 with an offset of 20! rather than patching them one at a time.
It seems to be an issue I come across more and more with some of the multi channel LED fixtures you see these days.
Im not sure what syntax you could use as the 1/2/406 layout is used for multiple DP's, maybe pig + then the offset amount?
Thoughts..
B
