Hello, it would be really great to define the open white for led fixtures. This is going to be really important for v3.0. Pixel mapping without defined white looks rose at the moment. Cheers, Martin
I can't comment on anything related to pixel mapping on the console at the moment...... Totally understand the scenario though having done more festivals than I care to remember. You are more concerned about "white" in a piece of content correct? I would think simply applying an overall "correction" CMY palette on top of the content would fix the problem quickly and easily since it will be more than just White that looks wrong.
If not, this sounds like the type of thing I would address via "Offset" under "Edit Fixtures" typically. Similar in nature to when some festival hangs all their VLs 90 off from "normal"....just put a +90 or -90 Offset to Pan and you are good to go, except you do it for CMY on your LEDs.
