Is it possible to make the Midi Viewer not clear its history if the window is closed. For example you have the Midi Viewer on screen with a filter set eg: Midi Note#. Then you change your view which closes the viewer, when you return to your original view with the viewer open both the history is gone and your filter is cleared meaning you have to type the filter back in every time.
