Currently when you are updating a cue you have to sign the palette and then press ok. Is there a way to change that in the same auto-update window to press update palette instead of ok without signing palette ? Or make a preference where I can activate the signingbox permanently. Kind regards, Henrie
How would you handle that if there are more than one palette is updateable? eg you changed color and position but only want to update the position palette?
I think the default should be all pallets checked on as you usually want to update pallets with what you have done. If you did not want to update position then you would un check position. It would speed up normal programming. Vector and MA2 work like this.
