I haven't come across a default DMX map included with Resolume 6. There are so many ways to setup Resolume, and the endless layers, columns, Effects and Parameters. Usually you have to setup your own Dmx Map, you can save this and recall it on other compositions.
Resolume DMX Map Shortcuts > Edit DMX (Ctrl+Shift+X) In this mode, you get a shortcut tab next to Files/Compositions/Effects/Sources Here you can load/save configs.
Perhaps load the Resolume 5 layer into the fixture builder in Hog4 and make it your own for 6.
Resolume 6 doesnt have any fixed mapping anymore (like V5) has. You can map any parameter, button etc yourself. But there is no more "fixture" mode. Has nothing to do with HOG.
