Hello everyone!
Found an interesting thing.
	Full Boar 4
	Hog OS 3.13.0
Repro:
- Create a Cueslist with i.e. 3 Cues (Cue 1; Cue 10; Cue 20)
- now select some fixtures and touch some parameters
- Press „Record Cue 1 Thru 20 Enter“ and select hit Merge in the pop-up window
- Now you should have 20 Cues in total instead of the original 3!
- This doesn’t happen, if you use „Merge Cue 1 Thru 20 Enter“ or „Record Cue 1 Thru 20 Select Merge from the bottom toolbar Enter“
