Can we please use in RGBXXXXX-fixtures that have a real intensity channel also use this and not virtual intensity or fixed to 255.
I know where it comes from, but really the minority of users uses I Red U Green etc. so mutexing is not an issue.
And with multicell fixtures where the masterpart has also an intensity this makes cloneing impossible as you loose intensity infos.
Or that you cant run another intensity-effect from the master intrensity on top of an effect or pixelmap on the cells.
I had several support calls during the last weeks re. this issue.
So please revise the libs so that we have a real intesity channel whenever its there. Also lot of manufactures have adapted there internal masterdimmer curves for smooth dimming via the master channel.
