With MVR becomimg more and more a standard it would be great to use this also for patch-import and plot creation, as there is xyz data, just let the user decice to ignore which axis when creating the plot.
For the naming issue of fixtures there could be matching tool that proposes matching names or you could select them manually.
Something like that has alreay been requested a while ago when Capture became able to export patch data.
With all major visualisers and consoles being able to import and sometimes export that file format it would be a pitty if we can´t do it.
