Hi, I'm just learning to use this software, and I'm self-teaching. I've read/watched a lot of tutorials, and I've done a lot of online searching/reading. So far, my biggest draw back is still removing things from the Master Cue list. I'm following all the steps in every combination I can think of, but the only thing that works is a Clear All from the page options. I've hit [Delete] and the [Master Cue #], but they won't come off. Any ideas? Another step I'm missing? Making sure x, y, and z are cleared or on first?
Hold down CHOOSE for the fader you wish to clear and hit delete. This deletes it from the master, but does not delete it from the LIST pool. If you want to delete the entire list completely, hit [LIST] [X] (where X is the list number) [DELETE].
Thank you for the help. This is what I am doing and it doesn't work. In case it helps, I'm using a touch screen laptop, digital version only. Not sure if that's interfering, but I'm wondering if "hold down" the button on the touch screen doesn't work the same way?
Also, just to make sure I'm not completely dumb - if I want to delete CueList #82 from Master Cue #10. You want me to hold down the #10 button in the master list and hit delete at the same time, right? This will keep Cuelist #82, but remove it from the master.
Then you need to use the "keyboard" shortcuts in order to hold down keys.
Hold SHIFT…click on the CHOOSE button of the master you want to delete (the window should show it depressed after you click on it)…then click on the "delete" button. It's a two button press so touch screens do not have multi touch.
