Is it possible to editing timecode values for more than one cue by selecting the wait cells and turn an encoder forward or backwards maybe by pressing together with a hardware button? Thank you in advance, Faren
"You may need to change the timecode value for one cue, and then change the timecode values for subsequent cues by the same amount, to keep the same relative timings. For example, you might have a series of cues where each one is triggered by timecode one second after the previous one. If the timecode value triggering the first cue needs to be increased by 12 frames, you may want the values for all the subsequent cues to also be increased by 12 frames to maintain the 1 second separation. Hog 4OS allows you to do this easily:
Open → Choose : open the Cuelist window.
Click and drag to select the Wait cells for the range of cues you want to edit.
Press Set.
Edit the timecode value of the first cell then press Enter. All the selected timecode values will be adjusted by the same amount of time added or subtracted from the first value."
Yes, I know ... I thought there is another trick ... I thought that this was possible at Hog2 at the time ...? Might be sometimes faster than getting the new time to type manually in. But Thank You ;-)
