I have a question/issue. I am trying to record a time only palette for delay which includes segments (segments of 5). I know segment information itself can´t get stored but the hard values in the programmer follow the fan created in segments (see attached pic 1). Then I stored these values masking time only. However, when I recall the palette, the programmer shows the delay at 0, no timing stored (see attached pic 2).
Also, if I try to enter exactly the same values manually (with no segments selected), I get same result in the palette. If I try with fade instead of delay I have same issue.
Why is it? What could I be doing wrong?
Using v3.15.1 (b3142)
Thank you
