Hi Hog, sorry for my English, question? When I work at a festival, I like to work with the scene window, using the add release end cue option, this makes it much easier to select the parameters I need, color, gobo, and some effect, all separated by different scenes, but when activating an effect that has a certain number of segments recorded, I would like to have another scene which only changes the segments and respects the effect, is this possible? or how do you work your effects in a festival
