ETC - Community
Site
Search
User
Site
Search
User
Control Consoles
More
Hog 4 Lighting Controls
Visualization
Light Converse - connectivity problems LC and Hog4PC
More
Cancel
State
Not Answered
Date
henrie
Date
Fri, Mar 21 2014 10:41 PM
Replies
Subscribers
3 subscribers
Views
Users
0 members are here
Options
Share
More
Cancel
Help!!!
I'm using 2 Mac mini with Windows 7 Home 64bit running in bootcamp.
Both PC's won't connect with Roadhog 4 or Hog 4PC. The Pig connect keeps searching for port 6600.
Anybody a solution??????
0
marc lorenz
over 8 years ago
What are your IP and network Settings?
Have you disabled all unused network-devices?
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
henrie
over 8 years ago
tried everything: fixed ip, dhcp......
the pc's do see each other but after that the connect window freezes with:
Connecting
No server
Scanning for show on port 6600
The 4th line in the hog4 network for visualizer doesn't pop-up
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
marc lorenz
over 8 years ago
Only have one network adapter active (disable all other, not just unused, right click and disable)
Make sure that all virusscan and firewalls are turned off.
Also check that you have the correct visualizer connectivity tool installed
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
henrie
over 8 years ago
Only one network is running.
No wifi etc....
We have tested the same showfile on a Roadhog 4 with a Windows 7 PC and that's running good.
The only difference is that my windows is 64 bit.
Could that be the problem?
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
marc lorenz
over 8 years ago
It is not depending on the showfile.
Running network is different from enabled network-devices...
I mean that only one network adapater is enabled, all others should be disabled.
Try to install the same version of HOG PC that you have installed on your Console.
Turn off all firewalls, virus-scans.
Enable DHCP Server in your Roadhog
Set the PC to automatic IP Settings
When you start your show on the roadhog, and then launch HOG PC do you see the option to connect to that show?
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
henrie
over 8 years ago
Hello,
Yes checked everything. No other network is running.
This problem is with 3 Mac pc's
Is there Ă problem with the 64 bit Windows 7 and LC ?
Strange is the Same setting with a Windows 7 32 bit is running. WiFi om or off doesn' t effect it at all!
Kind regards.
Grt,
Henrie
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
leggy
over 8 years ago
Are you connecting through an ethernet port, or are you using an ethernet to thunderbolt adaptor?
Also, have you disabled your Bluetooth?
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
henrie
over 8 years ago
Thanks !!!!!
Bluetooth disabled and it works :)
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
marc lorenz
over 8 years ago
Like I always said from the beginning: disable ALL unused network-devices
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
leggy
over 8 years ago
Glad you're up and running
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
Top
