Light Converse - connectivity problems LC and Hog4PC
Help!!! I'm using 2 Mac mini with Windows 7 Home 64bit running in bootcamp. Both PC's won't connect with Roadhog 4 or Hog 4PC. The Pig connect keeps searching for port 6600. Anybody a solution??????
So, first of all I'll mention I have followed all manuals and tried all the settings from this thread.
My main problem is the connectivity app won't start when I start Light Converse. I'm on Windows 8.1 with the latest LC and HOG 4 PC (same PC, using 127.0.0.1 loopback)
Tried reinstalling the connectivity app. Does just the same. Is this actually an app? I can only find 2 DLL files in the folder the app installed too. (so I can't find a way to manually start the app)
Depending on your dongle you can use artnet, hognet or also MA-net Remember that if you would like to use art-net you must use the fixture-link output of your HOG
Depending on the version.... IF you have the Design Dongle then only hognet will work, if you have the Media Dongle then you also can use other protocols
