Hey all,
I am very new to light converse so bare with me. I have a file from Light Converse for the Hog Factor. When I run Light Converse everything works fine however the program opens in a small window. It doesn't open full screen. I believe you change this in the displays tab. When I click on it however the plot portion of the visualizer expands in the small window. Then when I go back to displays button all the other buttons including the displays button stops working. I have to use task manager to close the program. I am running 64 bit windows 10. In task manager it says light converse is 32 bit. What do I need to do to fix this?
Kyle
