ETC - Community
Site
Search
User
Site
Search
User
Control Consoles
More
Hog 4 Lighting Controls
Visualization
Light Converse - Can you create a time code with the Hog 4 PC and Lighting Converses
More
Cancel
State
Not Answered
Date
objectedbear431 - Former HES Forum Member
Date
Wed, Oct 23 2019 2:56 AM
Replies
Subscribers
3 subscribers
Views
Users
0 members are here
Options
Share
More
Cancel
So I am currently trying to learn the Hog 4 console, and I want to start messing around with time coding.
As of now I am using the Hog 4 pc along with Lighting Converse Demo as a simulator on the same computer.
To create a time code for the lights on the simulator, do I need to invest in an external midi box? Or am I able to create a time code with my simulator with out any external hardware?
0
Maegan Wilson
over 3 years ago
You can simulate time code in Hog 4 PC to achieve this. Unless other programs need to be aware of the timecode, I think this is the easiest.
To simulate timecode:
1. Open the cuelist settings for the cuelist you want to be timecoded
2. Set the timecord source to console 1
3. Enable time code on the cuelist
4. Close the settings
5. In the cuelist window, select View Timecode to open the timecode toolbar
6. Select Simulate in the timecode toolbar
When ready hit Go on the toolbar. Go will start and stop the timecode. To go back to 00:00:00, then select jump and select 00:00:00.
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
over 3 years ago
Can you use the simulated time code with a lighting simulator like Light Converse?
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
0
Maegan Wilson
over 3 years ago
Usually the lights in Light Converse are responding from triggers via Hog, so the timecode would need to go into Hog, which simulated time code works for.
If Light Converse needs the timecode also, then you need another solution. Hog 4 PC's simulated timecode only works inside Hog 4 PC.
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
Top
