ETC - Community
Site
Search
User
Site
Search
User
Control Consoles
More
Hog 4 Lighting Controls
Visualization
Light Converse - Moving heads slow to change
More
Cancel
State
Not Answered
Date
lvtech - Former HES Forum Member
Date
Fri, Nov 22 2019 4:41 AM
Replies
1 reply
Subscribers
3 subscribers
Views
Users
0 members are here
Options
Share
More
Cancel
First post here. Sorry in advance for anything wrong. I'm sure this is an easy question. I just got a Road Hog 4 and have some Chinese Beam 200/230 patched in. I'm running the Clay Paky Sharpy Beam Vector profile 20 channel mode. They pan and tilt perfect. However when I try to do almost anything else with them, it takes a solid 30 seconds to change. So if I were to move the intensity from 0-100%, it will slowly raise up over about 30 seconds. Same with changing gobos, frosting, colors, etc. Whats the best way to change this back to the speed I can manually move the wheels/fader? Thanks!
0
Cormac Jackson
over 2 years ago
Best guess there is a timing channel that is not functioning correctly withing the fixture profile ?
If you select the fixture and then select the beam function and then look for timing or speed is there a way to change the default speed or alter the speed and then see if the intensity fade time ls correct ?
Cancel
Up
0
Down
Reply
Verify Answer
Cancel
Top
