cue lists in hog4 vv eos
Hiya
I'm currently learning Hog4 after Eos and I'm confused by the difference between cues and cue lists/stacks. For reference, I'm learning off of the "Learn Hog4 Hedgeucation" series.
Basically: In eos, A cue is a state that hold data for every patched fixture in your rig. So if you want 1 thru 20 out in cue 1, they'll hold the value 0% in that cue.
In the Hog series, they show that you can cycle between cues that somehow add onto each other. For example, He has a set of cue lists for each fixture type in a different colour, and he's able to select 2 lists which target different fixture groups. In this scenario, the cues add ON TOP of each other instead of cancelling the previous value out. Hope this makes some level of sense.
Can someone please explain this to me? Is it just a difference in how they store value in cues in Hog? Is it to do with cue LISTS vs CUES ? Or something different still?
I'm also curious on how those interact when they are set on masters, if u also feel like breaking it down for me.
Thank you very much for your help :)
  • Hey,
    I don't feel like I understand the question... In EOS a cue is part of a cuelist and in HOG a cue is part of a cuelist. In EOS you can select only a few fixtures to record into a cue, in HOG it is the same.
    For example: In both EOS and HOG you can record different states of fixture 1 in different cues in cuelist 1 and different states of fixture 2 in different cues in cuelist 2. In EOS I would open fader config tab to configure fader 1/1 to hold cuelist 1 and fader 1/2 to hold cuelist 2, in HOG I would type 'list 1 move' and select fader1 and do the same for list 2. As far as I know it's the same situation you're in now. You can control both fixtures independent per independent cuelists. In EOS you only see the last fired cue in command line. But you can configure both cuelist as phantom cuelists to not see the last cue of them in command line.
    A big difference I see is that in EOS you globally configure cuelists to be tracking or cue only, in HOG you can configure this per cuelist.
    Does this help in any way?
    Regards
    Lars
