for the life of me, I can not get the iPad hog4remote and console connected.
In the link of your advice article It says nothing about the hog4remote ! .. I think I am on the wrong track here. What is a wing and or a winget??
Was this the correct image?
Quick update. I think I have everything done correctly however I still cannot remotely access my console any suggestions
The IP address used on the console will not work. A 127.0.0.x IP address indicates the console is on a Loopback adapter, rather than looking for a network. A default HogNet address would be 172.31.0.1, and if you are planning to change the console's IP address, you should change it to 192.168.1.X, where X is a number different than any other devices are using on the network.
Look into your console's HogNet settings in the Control Panel to correct this.
OMG.. thanks.. Im going to get this.
