OSC Interface for Control App (Android + iOS)
I've written a fairly basic Hog-4 OSC interface in JSON for the "Control" app which is available on both the Android and iOS platforms.
Once you have Control installed:
- add an Interface by pointing it to:
www.retinalresonance.com/H4OSC.js
- then make sure you set a "destination" in Control that matches your console's IP and Port settings for OSC in. (ie: 172.31.0.1:7001)
Note that currently this only goes one way...device to console. Console to device messages (such as LED status, etc.) is not yet implemented by me for this.
I have had no success in testing this myself as I have been unable to get OSC in to H4PC due some network oddities on my end, but apparently others have used it successfully.
I designed the layout for a Samsung Galaxy Note 2 (love the stylus on it for things like this!:headbang:), so you may see slight variations in the layout between different devices.
I'm hoping you all have better success connecting and using this. Please report any issues back to me so I can adjust for them if possible.
Enjoy!
  • Marty,
    FYI, I got this to work on my Droid4 phone. The UI went off the screen a little bit at the top, but it worked pretty good. Looking forward OSC out added. Thanks for posting this.
  • I have almost all the keys working perfect from ipad to computer and backwards, but the faders and encoders simply do not respond, does anybody knows how to fix this?
    Thanks in advance !!!
  • [QUOTE=gemat;64047]I have almost all the keys working perfect from ipad to computer and backwards, but the faders and encoders simply do not respond, does anybody knows how to fix this?
    Marty's Layout correctly sends fader and encoder commands to Hog4.
    Hog4 does NOT output encoder movements back to OSC devices.
  • Thanks Chris, I understand that Hog4 does NOT output encoder movements back to the iPad, but, I just can't move the faders on the PC, neither the encoders, I suppose that if I move them in the iPad, I have to see them moving in the Hog PC, is this correct? What am I doing wrong? everything else is working perfect.
    Regards
  • Encoders and faders through osc are not available on hog4pc. That functionality is currently only available on an actual console.
    Kurtis
  • [QUOTE=gemat;64092]Thanks Chris, I understand that Hog4 does NOT output encoder movements back to the iPad, but, I just can't move the faders on the PC, neither the encoders, I suppose that if I move them in the iPad, I have to see them moving in the Hog PC, is this correct? What am I doing wrong? everything else is working perfect.
    Regards
    I misunderstood your question. If you bring up the MIDI viewer you will see it screaming error messages about that feature being disabled for the PC version.
  • Thanks Marty Postma for this wonderful and informative post.:headbang:
  • Apologies if this has already been discovered and mentioned...
    I just found out a couple of days ago that in May, TouchOSC was finally released on Android. I have tested the HES template made for the iPhone on my Galaxy S3 and it all works very well. Only the tabs at the top of the screen were missing text but not sure if they ever showed on the iPhone?
  • The text does appear on the tabs on the iPhone. There is currently an issue with iPod Touch (5th gen) that prevents the text from showing on the tabs. Perhaps the Android issue stems from the same origin. Hexler is supposedly working on it.
  • What App are people using on Iphone to make this work, not having much luck at the moment.
1 2 3 4
