Hog 1000 Defult Libary
Hi Guys, WE have a large Stock of the robe colorspot and wash At series and the current version of the software doen't have these fixtures in the libary. We can load the libary off a disc but being that the console lives in a hire department I would like to remove the reliance on floppy discs as much as possible. any thoughts? a few other hire companies were after this as well. Is there a program that we can edit the main libary? so we can remove the fixtures that we wont come into to contact much ect ect.
  • Michael,
    Please understand that HES/FPS is no longer developing on the Wholehog 2 platform. The feature you have requested would require developer resources and time. This would take away from development on current products. We do offer newer options which include full support of libraries AND a method for you to add new libraries to the older operating system.
    A change as you describe is not a "quick fix" as it requires development of the library removal, addition, packaging, etc. Then testing would be required and finally building of the new software. The Wholehog 2 OS has not been developed on in over 5 years and the current development team is dedicated to the modern Wholehog 3 OS. It would cause a major detriment to our current plans and goals to implement this feature that is only requested by a very small number of users.
    I encourage you to take a look at the suggestions that have been made in this forum and consider upgrading to a modern FPS console instead of just running off to another console.
    thank you for your understanding,
