:684: Parkin with 2.3 b1928 compleatly locks that channel and can not be releast with out node reset I to found this out last night but the internet was down this sucks nun of the tricks from the past will get you out of this pile of pigs pooh :angryfire:
Yes. The problem with park leaving values stuck (appearing in the output window in blue text as if they are controlled by an editor) has been fixed in the v2.3.1 software release. You can now park or unpark from the programmer, any preview editor, or the parked editor without problems.
We've also added functionality so that when you unpark, the parked values are brought into the current editor. This gives operators the ability to gracefully fade these values out, rather than have them snap in a time 0 as they did before. These values are marked as recorded when they are brought into the editor so that they won't be included in record operations unless they are touched first.
Wholehog software v2.3.1 is available for download from the Flying Pig Systems web site at www.flyingpig.com.
