Routers
Which router(s) do you guys use. I am looking for one to connect 1 H3, 2 DP8k, and to use as a wirless access point for a tablet PC. I am thinking an N1 router with at least 4 ports. Which ones do you guys use in your systems, and would you reccomend them?
  • Just a thought...Middle Atlantic can provide rackmount shelf with a custom faceplate for nearly anything. I use them all the time for things like consumer DVD players. The bottom of the shelf also has slots that can be used to lace down the cords so they don't come loose. And they have templates for a pretty impressive amount of gear already on hand. You could probably even get them to do something that would allow you to remote the antenna(s) to the front panel like Shure does with their wireless rigs. Some routers have add-on antennas that might work here. The shelves cost under $100. And be sure to order the clamp option which will secure the item on the shelf from moving about in transport.
