Why did I bother to upgrade my iPC!!!
Hi all
I decided to upgrade my iPC to the current version and now I get the "can't connect to front panel error".
I have tried to install the latest image and all i get is a cursor flashing in the corner of screen.
I have also tried to download the V8.2.2 image but not sure if i have the correct one as this doesn't work either. Can anyone shed any light on this as I now have an expensive blue door wedge!
Many thanks
S
  • hi friends:
    My strange experience.....with iPC
    I restore iPC Console with cd restore image 8.2.2.
    Process of restore are ok, the console work with the HOG iPC FRONT PANEL.......uffff
    next step Burn one cd data with 3 files:
    (1)Hog iPC Configuration Panel
    www.flyingpig.com/images/spacer.gif
    Version:
    v3.0.2 (2440)
    Release date:
    March 4 , 2009
    Notes
    : This version requires XPe Image Release 8.2 or greater.
    (2)Hog 3PC
    Version:
    v3.0.2 (2440)
    Release date: March 4, 2009
    Note: This version requires XPe Image Release 8.2 or greater
    (3)Hog iPC DMX Processor 8000 Firmware
    Version:
    v3.0.2 (2440)
    Release date:
    March 4 , 2009
    Notes
    : After upgrading to version 3.0.1, install this update if you are connecting a DP8000 to a Hog iPC with less than 1GB of Ram. Install via the Hog iPC config panel or Hog 3PC start screen.
    I upgrade the iPC configuration panel to v. 3.0.2 (2440) process are ok.
    When go to upgrade the hog pc3 v.3.0.2 (2440)
    Apareed this legend
    Hog3pc 3.0.2 2440
    Error writing to file: C:\program files\flying pig systems\hog 3pc\helptext\ru\sect-safety_en.htm.
    Verify that you have access to that directory
    some one can helpme......please.......:hogsign:
  • Have you used the Checksum to make sure the download isn't corrupted or simply tried downloading the file again?
  • The issue causing older iPC models to display a "cannot connect to front panel error" has been resolved in the iPC restore image released yesterday (April 1). The iPC restore image version is 8.4.0.
  • Push!!!
    I currently have the same problem like Granados E with an iPC.
    Is there a fix for it?
    Best regards Roman
  • I've had the same problem. The problem come from upgrading Hog 2. If you don't update the hog to you won't have these problems.
  • I already got the solution:
    The videoframebuffer - thing in the bios helped me.
    Maybe someone can correct the minimum specs on the update site.
    I had XPe 8.2.2 installed and it didn't worked.
    Cheers Roman
  • Thanks Roman,
    We will run some tests and update the webpage...
1 2
