ACN, ETCNet, Artnet, Oh my.
So I've tried searching the forum for ACN, and it won't work...as it's only three letters. So I'll just post a new topic.
This is what I've gathered and believe to be true...I need some confirmations...please :)
-Wholehog OS does output Artnet with the use of a DP8000.
-Wholehog OS does output Artnet from a PC (HogPC) without the use of a DP8000, or Widgets. (Hmm, so what stops the general public from purchasing a cheap artnet node in lieu of a more expensive HogPC Widget?) Or then again...does it not?
-Wholehog OS does NOT output ACN (Advanced Control Network).
-^^Therefore Wholehog OS is not compatible with an ETC Net3 control network without the use of networked DMX Input Gateways.
-Wholehog OS does NOT output ETC Net2.
-Therefore...Wholehog OS is incompatible in every regard at the current moment with an ETC Net2 or Net3 control network...without using DMX Input Gateways.
Anyone, anyone? I just need to make sure the research I've done is correct...
