Source Four Mini Dimming Options
Hi all,
I'm looking at getting some Source Four Minis for various tasks (to be used at events in car showrooms, cafes, and other small venues, but not as a permanent install) and want them to be as versatile as possible. Therefore I want to have each fixture be dimmable, but because of the setup loacations having a 12 or even 4 channel dimmer isn't ideal. So I'm looking for a way to have a separate dimmer on each fixture.
My question is what's the best way to go about this? I know I could get a full 10A (I'm in Australia, so 240V 10A mains) unit dimmer but this seems overkill for a 50W fixture. My thoughts so far are:
One option is perhaps to get the low voltage version and use a City Theatrical D2 dimmer (the D1 is much larger) or similar, along with a 12V DC power supply. Depending on the PSU size it could all be mounted on the yoke making for simple set up and pack down. But I'm not sure this is the most elegant solution to the problem.
Another thought was if there was a DMX controlled dimmer similar to those used to dim halogen lights in people's homes. The domestic turn knob dimmers are small and cheap, and seem to be a great option if only they had DMX. Maybe a DIY solution based on these dimmers would be something to investigate?
If anyone has any thoughts on these ideas or ideas of your own regarding how to address this they'd be greatly appreciated.
Kind regards,
Kieran
5 Replies - Page 1 of 1
  • just to make sure: this is about source four mini with the tungsten low voltage lamp, not the LED version, correct?
  • In reply to ueliriegg:
    Yeah that's correct. Though if there's an easier way to dim the LED version, then I'm totally open to that.
  • In reply to KCrayn:
    the trackmount version of the Irideon FPZ (which is the source four mini LED with zoom lens) has integrated DMX control, its canopy mount version has DMX and DALI if i'm not mistaken. if that helps at all?
    the source four mini LED itself is line dimmed.
    mistook the source four mini LED for the irideon versions...
    [edited by: ueliriegg at 5:31 PM (GMT -5) on Wed, Sep 13 2017]
    Thank you, yeah I've been looking at the Irideon FPZ and the extra light output would be really useful, but I was hoping to use a 19 degree lens
    HI KCrayn,
    While it sounds like you want shutters, we did just announce the Fresnel version of the Irideon line. This has a huge zoom range form 9 to 78 Degrees. The Irideon WLZ: www.etcconnect.com/.../WLZ.aspx
Page 1 of 1
