Color source spot 1 channel mode programming
I just installed some CS Spots using the one channel mode, one of the spots did not do anything when sending it DMX. I learned that you have to program P.01 a color with recording using the mode 3 sec. that is fine. But is there a way to set the spots back to factory settings so all Presets of the the spots are the same again without using a desk.
And is it possible to save the preset using RDM. Because if you want to adjust the colors of all spots to one color you need to fiscally go to all spots.
Marnix Kuling
