Adding new device offline results in RDM enabled
Build 40
When I drag a new (offline) 4 port Gateway device into my configuration, it defaults to RDM being enabled on the ports. This is not the case when a device is not in the config, and was brought into it by dragging in an online device.
2 Replies - Page 1 of 1
  • When you select the offline GW and look in the property editor, does the SW version report at 7.0.0 or 7.0.1? If so then RDM should be disabled and it sounds like a possible bug. If it reports as 6.0.1 or lower then RDM is enabled by default. Also, though, it should drop in as the latest version by default too...
  • In reply to Chris Blad:
    And actually I just fired up build 40, and 7.0.1 does have it enabled in offline mode.
Page 1 of 1
