starting with (likely) 3.1.0, the syntax
Address 1/ Move To 10/ only moves the first fixture on that universe.
Using the command a second time will move channel 2 in this example. Switching to Patch Address has no effect.
Oliver.
Oliver.
Hi Oliver,
Appears this is new as of 3.0.0.
A work around is to do the following:
Patch Address: <only needed if you do not know the channel numbers, but do know which Universe you want to move>
1 Thru 10 Enter
Patch Channel:
<We keep the channel selection from Patch Address>
<Your example> Chan 1 Thru 10 <Now posted on the command line> At 10 / Enter
This will move those addresses to Universe 10.
[EOS-53311] Patch Address: Move To only moves the first address selected
