Hi, please I upgrade console Eos Ti and nomad server to Eos3.1.1 but before start write to me: your device RESPONSE MIDI Gateway need update to version witch one is not in updaterator available.
Sorry for my english.
Best regards Michal Zeman.
Hey Michal,
just follow the steps of the message: Go into the Shell-Settings and navigate to Maintenance and scroll down to the Firmware Update window. There should be one of the modules marked red. Click on it and "Update". Click the version with number 2.2.0.3 and start the Update. Please reboot the console after the update. :-)
Kind regards,
Markus
When ifollow the instructions, console vrite to me:You can´t update dhis device wihout Updateator. :)
The nomad server does not see the device through the network (UpdateaAtor works, sees the device but does not have the required firmware version) and via USB update does not work
you are right. We are working on the firmware update for the Response MIDI Gateway but it's not released yet.
If you only use 1 MIDI Gateway connected via USB it should work with the current firmware as well.
So far you can just ignore the message
I'll keep you in touch
