b183: Certain macros containing {Offset} and {Close} won't fire
The following macros won't fire (Tested in the english and german version | Results are the same):
{Offset} {Num_Groups} [#] {Close}
{Offset} {Chan_Per_Group} [#] {Close}
They work without {Close} and they even work if you add any command in between the digit and {Close}.
So something like
{Offset} {Chan_Per_Group} [#] {Interleave} [Clear_Cmd] {Close}
will work.
{Offset} {Num_Groups} [#] [#] [Clear_Cmd] {Close}
however will not, as [Clear_Cmd] clears both digits, which is another bug.
Also: clearing {Offset} from the commandline deletes the digit to the left of it as well.
This is probably a topic for the general forum but another thing concerning {Close}:
If you use it as a command in a MagicSheet it ends up causing a syntax error.
This is not specific to {Close} as well.
The command-field in MagicSheets is very inconsistent in that it just won't allow certain commands.
It almost seems like a feature that was implemented but never fully realized,
which is sad, since it could potentially keep Macro-, Group- and Palettelists free from stuff that is MS-specific.
