This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Custom Direct Selects
Multiple Custom Direct Selects:
You may now have multiple Custom Direct Select Layouts.  Choose the Direct Select layout number in the popup (0.001>9999.999):
Confirm Creation
Custom DS Editor:
For initial setup (or large edits) of the Custom Direct Select layouts, clicking on {Open Custom DS Editor} (button shown in above screenshot) will open a new blind tab (39).  (See alternate popup option below)
You then can select cells with window or single tile selection:
Using the "Target Selection Menu" on the right, assign to be Channels, starting at 1, offset of 1:
(Offset will appear when multiple tiles are selected, otherwise if a single tile is selected you get Start and End)
Cut/Copy/Paste/Delete tools with "clipboard preview":
{Jump To ...} (allows you to jump to that Tile number):
It is also available in Tab 4 (configuration Popup and on the Navigation Bar):
Popup "Target Selection Menu":
The Menu found in Blind Custom Direct Selects (Tab 39) is also available as a popup in Live/Blind - Direct Select (Custom) (Tab 4).  To access, Right Click or Double Click:
Console Buttons (including "Beam"):
Direct Select Navigation (Jump To... and Next/Last Page):
Jump To...
The lists below are not labeled ("CT" being "Custom Template"):
Resulting CDS Tiles
Here with a mix of labeled and not (Tile does not show label only the CT Number):
Direct Select List Icon:
In Tab 39, Select your Custom DS number, then {S1 - Direct Select Icon} (or click on the cell)
See separate post Target Icons for other new options.
