Looing for a way to print the fixture layout in setup. Application is to make a magic sheet what I can better label and define what is what. I know you can build a background image but you have to play back and forth to get everything just right. If you could print the layout then you can make a magic sheet to match it.
Anyone know of a way to do this?
If not can we get it added?
