Erwin
Posted: Saturday, August 2, 2014 1:11 PM
Heya (again)!
In order to see changes done to a fixture's profile in the actual program it looks like it is necessary to restart the application or close and reopen the project file.
Detail:
I change a parameter of a fixture used in the project via the fixture editor. As mentioned in the manual I reset the fixture to its library default. Unfortunately the change is not reflected immediately when I play a test program. I either have to restart the application or close and reopen the project file.
This is extremely cumbersome when calibrating hundreds of fixtures...
Is there any way to edit a fixture's profile and have the change reflected in the project without the restart or close/reopen routine?
Thank you,
Erwin
