TPC Button activate/release
Hello all,
Trying to program my TPC. FOr now I have one issue:
My page has three buttons: A, B and C. It should not be possible to activate 2 buttons at the same time. The property "Actuation" is set to "Maintened" for all buttons.
Example:
User presses Button A.
Button A is active, timeline A starts.
User presses Button B.
Button A and timeline A should release automatically.
Button B is active, timeline B starts
I can start and stop the timeline using the triggers and scripts. What should I do to release the buttons?
Thanks in advance,
Dennis
  • First of all, you want the "Momentary" actuation.
    "Momentary" means "Do a thing when button is pressed"
    "Maintained" means "Do Thing A when the buttons is pressed the first time, and Thing B when it is pressed the second time".
    Secondly, to indicate status of things like Timelines you want to change the "State" of the button.
    To do this, create a trigger that uses the "Set TPC Control State" action.
    Eg Button 001 drives Timeline A.
    Create three triggers:
    1. TPC Button > "Button001" is clicked > Start Timeline A, Release Timeline B, Release Timeline C
    2. Timeline Started > "Timeline A" > Set TPC Control State "Button001" state "Red"
    3. Timeline Released > "Timeline A" > Set TPC Control State "Button001" state Default
    Now repeat for the other three timelines, making sure to change which button is used to start them and which button changes "Control State" when the timeline starts or stops.
  • Richard is spot on on  this. There is a slightly easier way to track button status though. We have to make an assumption here first though.  The key field for the button in TouchEditor is "key" here. By default TouchEditor uses the following syntax for button keys: The word "button" followed by a three digit number.
    Now the  assumption that we have to make is that the following is true
    • button001 controls Timeline 1
    • button002 controls Timeline 2
    • button003 controls Timeline 3
    • button004 controls Timeline 4
    and so on.
    once this relationship is established we can to the following:
    1. Create a Timeline Started trigger
    2. Set Timeline in the Parameters section to Any
    3. Add a Set TPC Control State action
    4. Set the Controller to 1 (typically)
    5. In the Control field in the Parameters section type the following: button<3d>
    6. Set the State drop down to your preferred On color (typically green or red)
    7. Create a Timeline Released trigger
    8. Set Timeline in the Parameters section to Any
    9. Add a Set TPC Control State action
    10. Set the Controller to 1 (typically)
    11. In the Control field in the Parameters section type the following: button<3d>
    12. Set the State drop down to your preferred Off color (typically default)
    Now whenever a timeline is turned on the associated button will turn on and then the timeline in released it will turn off.
    So what is this actually doing?
    1. Anytime a timeline is started or stopped one of these triggers will be fired
    2. When that trigger is fired a number will be captured as a variable.
      1. For example if Timeline 15 is fired the number 015 will be captured
    3. That number is then injected into our Set TPC Control State action using button<3d>
      1. following our example: button<3d> becomes button015
  • That's all great when you want a single color for your buttons.  But what if you want a different color for each button..  I can get the "any" to work, but when I select a specific timeline, a specifical control and try a specific color, it doesn't work.  I'm sure I'm missing something.
  • Then Lua scripting is your friend.
  • The way I do this is to use a different key header for the buttons you want in another colour - eg RedButton<3d> with another set of timeline started and timeline Released triggers with appropriate states for these button types. Don’t forget to untick Absorbed on the first set of timeline started and released triggers.
    Does that make sense?
  • Thanks Neville,  So I have three buttons -001, 002, and 003.  Each are labeled Red, Green, Blue
    I have the Touch Button Events (toggle) working, wathcing the them running and released in the web browser.
    Then for each button, I have a Timeline Started & Timeline Released.  Timeline's are pointing to 1:RED, 2:GREEN, and 3:BLUE.  Red button will toggle on/off.  After unchecking absorbed, the red button will go off when Green or Blue buttons are pressed.  But I can't seem to get the Green or Blue buttons to turn green or blue..  Red is the only one working
  • Can you clarify a few intent items?
    Does the Red button toggle the RED timeline(timeline 1?) on/off?(same for green and blue)
    Do you want the state of the button to change with the button press that matches the state of the timeline it is associated to?
    can you share a screenshot of your triggers expanded or a copy of your file
  • update:  So I noticed in my other two Timeline Started/Set Touch Control States that it was displaying:
    Set control "button003" state to "Blue on all devices numberf from variable 1.
    The red triggers didn't have anything about variable 1.  To get rid of that, I had to switch the Touch Device to M-TS, change varialbe to number, then switch it back to any.  That changed the command line to .....Blue" on all devices.  Now it's working.
  • John,  it's telling me the file is not allowed for attaching it in here.  Give me an email and I'll send it to you.  From what I can tell, the timelines have to be released before the button color gets turned off.  So I haven't found a graceful way to release all with the Touch Button Event.  I have to start the RED, then release the GREEN and BLUE (and the other 4 timelines).  Doing release all just keeps the RED timeline from coming on, maybe that's a problem the Toggle action vs just StartTimeline.
  • jabadger,
    Is there any references, a programming book or any place where you can find examples, lists of commands on how to learn scription??  When you first wrote this, I had no idea what you were talking about.  I thought someone named Lua was sending me a friend request!!!  Then I saw an example of a Lun script in another thread.  Looks kind of like C++ programming.  Where do I get reference materials?
  • The Mosaic manual has a section at the end with examples!
