I want to buy a Tessera touch screen and some button stations, but before i want to be sure that these products suit my need. That's why i have some questions:
- Is it possible to block some of the buttons and let other work on the same button station during the show to avoid that people turn on the light on the stage
- Is it possible to sync the buttons if they turn on the same location
- I wanna make an interface on the touch screen with a map of the theater, each location will have blue and white light (with led strips). I want that user can press on each location on the map to turn the light on, and these locations will change color on the interface when we press on it to see which locations are turned on.
- My actual system is controlled with an Eos Ion and an ELC node, I want to use the ELC node to merge the Ion and the Mosaic system, do u think that there is compatibility problems, is there a better way?
- I have some POE ethernet Switches, what kind of Voltage and watts do I need for the touch screen and the buttons?
Thank you very much in advance
Laurent
