It appears to me that a Mosaic MSC running 2.0 (or 2.0.2) is not visible to a PACP running 2.1.2. Is this a known issue or a new discovery? Will I have to wait until Paradigm 3 is available to use the Mosaic 2 firmware?
The issue in Paradigm 2.1.2 is that the offline/online indication for a MSC running v2.0 won't work in Light Designer, but otherwise the Mosaic <=> Paradigm integration still works. Paradigm v3.0 will resolve the indicator issue.
