Output Live Control Broken (v2.2.3)
When choosing to selectively output groups under Output Live Control (via dropdown "Output by groups") and then starting Output Live mode the controller outputs no data.  This is even true if you select "Select All" under "Output by groups" which, in theory, should output all fixtures.  Controller log shows that Output Live has started however all values are output at zero.
