MSC distributed show playback
We planned to use several MSC2 controllers installed in different locations of the building. I would like to know if it possible to synchronize show playback or even create one show in designer software distributed between several Mosaic controllers? It can be required if lighting fixtures from different DMX universes connected to different MSC's should be controlled simultaneously in single show/scene.
Thank you!
