I am looking for a way to send the DALI commando : Maximum level and minimum level to a DALI address or group.
You cannot script Dali commands directly in Mosaic.
You have to pass these to another trigger using the enqueue function.
Also you can only set the maximum and minimum levels during commissioning of the Dali ballasts its not possible to change these from triggers.
You can set level, recall scenes and send command to fade up and down.
Tom
Thank you for replying.
As I was suspecting! I was hoping that it was some way to script Dali commands to sett the maximum and minimum levels. But I have to find another way to solve the challenge!
Benjamin
