Greetings! I have 3 MSC1 controllers in my project, each has a real-time trigger. Does the trigger work on a controller excluded from the network with the others, but if there is Internet access in its network segment?
Some of the triggers can be run locally but not many, Real-time triggers will only run on the Network Primary.
You might want to take a look at Mosaic Manager, this will allow you to config the 3 controllers as individual projects but sync timed events across them. Once you have done an upload from Mosaic Manager the information is stored locally and then it is not a problem is the controllers are disconnected from each other.
Tom
Thank! I apologize for the long reply. Can you tell me where I can find the Mosaic Manager?
Mosaic Manager is a included as part of the .zip (PC) or .dmg (MAC) file that you download to get Mosaic Designer.
