Hello! I use Mosaic MSC1 in my project. The network at the facility is divided into VLANs, but I need to see the controller in the Designer. How does Designer poll the network to find controllers? Can I specify Designer specific IP and port for connection?
Mosaic Uses Multicast for device discovery. Designer will always use this and when you upload it know which controller via the serial number not the IP Address.
Most other communication in a mosaic system is Unicast.
Tom
If your network has multicast off or you can’t use it in a certain scenario, you can manually search for the IP address of a controller. Look for the button next to where you’d assign a serial number.
